volume flow rate with fluid fraction 0 in FLOW3D |
January 31, 2023, 04:16 |
Sushmita Lamichhane
Rep Power: 3 |
Can we use vfr with fluid fraction 0 at outlet of the undersluice.
I tried using Specified pressure with fluid fraction 0. but the volume flow rate that had to be out from the outlet couldn't be attained as the flow has to distribute between two openings. so I have used vfr with specifying the required volume flow rate with 0 fluid fraction .. will this work? |
February 1, 2023, 03:40 |
Sehroosh
Rep Power: 7 |
Pressure boundary at Xmax. with 'Pressure Outflow' option checked, should do the job for undersluice outlets.
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 06:09 |
Controlling fluid volume fraction over time at the inlet of a pipe | Gwench | Fluent Multiphase | 1 | December 9, 2015 09:59 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 02:40 |
