Home > Forums > Software User Forums > FLOW-3D
Issues with fluid and geometry initialization
Old   November 14, 2022, 13:02
Default Issues with fluid and geometry initialization
Josh Morrison
joswomo is on a distinguished road
I am very new to using the Flow-3D software, and am having issues with initializing fluid and geometry in my model.
I have loaded fluid properties in the Fluids widget, specified a fluid height in the Global tab of the Initial Conditions widget, and have fully created my geometry components in the Geometry widget.
However, when I run my simulation the Solver Summary gives the following readings:
time = 0.00000E+00, cycle = 0, dtstbl = 1.00000E+20, dtcode = na, delt = 1.00000E-03
volume occupied by fluid = 0.000000000000000E+00
avrck-adjusted volume of fluid #1 = 0.000000000000000E+00
total active solid component volume = 0.000000000000000E+00
avrck-adjusted solid component volume = 0.000000000000000E+00
mass and energy audits
mass-averaged mean kinetic energy = 0.000000000000000E+00
open volume in mesh = 0.000000000000000E+00
avrck-adjusted open volume in mesh = 0.000000000000000E+00
fill fraction of open volume = 1.000000000000000E+00
solidified fraction of fluid volume = 0.000000000000000E+00
total fluid mass = 0.000000000000000E+00
cumulative fluid mass source = 0.000000000000000E+00
total fluid #1 thermal energy = 0.000000000000000E+00
total mass of scalar species 1 = 0.000000000000000E+00
total solid thermal energy = 0.000000000000000E+00
I have spent a good amount of time searching around but since this is what I am guessing is a pretty low-level mistake I have not found any documentation on the issue.
Thanks in advance for any assistance.
joswomo is offline   Reply With Quote
ERROR while simulating Fluid flowing through a rotating geometry venu1591 Main CFD Forum 0 January 7, 2022 09:21
[GMSH] Issues with importing 3D mesh of T-junction geometry into MATLAB manuelguzman61 Mesh Generation & Pre-Processing 1 February 8, 2021 17:25
Issues with geometry from Mesh to PreCFX Fluid flow Abhinavkothari Main CFD Forum 0 September 20, 2020 06:43
How to Extract volume of fluid inside Shell Geometry in ANSYS SPACE CLAIM vishal_295 ANSYS 0 June 17, 2020 08:29
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
