November 11, 2022, 05:07 |
Surface tension extraction
chenhaodong
Rep Power: 4 |
hello everyone! How to accurately obtain the surface tension in flow3d v11.1? I really hope someone can guide me, thank you.
Another problem is that I don't understand the surface tension pressure in the 3D post-processing function of the software. I don't know how to insert a picture, so I can't take a screenshot to show you. Sorry. Last edited by chenhaodong; November 11, 2022 at 05:09. Reason: Clerical error |
Temperature dependant surface tension - icoReactingMultiphaseInterFoam - Usage | Harris_Daniel | OpenFOAM Programming & Development | 3 | July 1, 2022 11:21 |
Solution not converging with Surface Tension modeling | faizan356 | Fluent Multiphase | 0 | July 28, 2021 03:53 |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 06:11 |
surface tension gradient using UDF; surface tension gradient as function of temperatu | marimuthusundar | Fluent UDF and Scheme Programming | 0 | June 21, 2012 05:48 |
VOF and strong surface tension effect | phsieh2005 | Main CFD Forum | 1 | August 30, 2005 07:56 |
