August 16, 2022, 11:10 |
Problem GMO / Wind Turbine
Sarp
Rep Power: 5 |
Hellow everyone,
I've been working on a simulation of a wind turbine at pool. My problem is;
For example when I modelled a simple floating cube. Mostly there was no problem but sometimes also the cube sinks and leave the domain to. I dont know why this happens, If you could to help I would be happy. Kind Regards, |
August 25, 2022, 08:33 |
UK
Rep Power: 7 |
Check the model dimensions and mass density of the cube. Take a look at the floating objects inbuilt example in HYDRO and it will show the setup (moving objects>coupled).
gmo f |
Wind Turbine - Rotation of the Baldes | moonomid | CFX | 32 | March 18, 2016 20:34 |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 18:18 |
wind turbine simulation inside the wind tunnel | shaohua | FLUENT | 4 | April 11, 2014 18:01 |
Ducted wind turbine (BC for the shroud) | Pepita | CFX | 4 | June 29, 2013 08:09 |
Wind turbine simulation problem | sanchovg2 | STAR-CCM+ | 12 | March 5, 2013 05:18 |
