Home > Forums > Software User Forums > FLOW-3D
Instability in falling aluminum droplets
Old   August 6, 2022, 12:11
Default Instability in falling aluminum droplets
Wilmer
wilmerecj is on a distinguished road
I am simulating the fall of 5 drops of Aluminum on a solid substrate, the model is composed of:
-Gravity
-Heat transfer
-Solidification
-Surface tension
- Viscosity and Turbulence
The control domain is 2󫎿.5 mm
I have the following problem, when the mesh size is up to 6e-5m it works quite well, you can see two drops fall, however when I reduce the mesh size below 5e-5m the drops do not fall directly, the fall becomes unstable.
what could be the cause of the problem?
wilmerecj is offline   Reply With Quote
droplet on demand
Sub micron sized droplets in reactingFOAM Scram_1 OpenFOAM 2 August 23, 2018 16:50
Stability and Realibility of microfluidic droplets storage in tube or storage coil devalvyas System Analysis 0 February 2, 2016 12:49
Falling droplets (DPM), rel. humidity > 100% ???? Wikie FLUENT 0 October 25, 2010 05:52
Number of Droplets per Cell viv05 OpenFOAM 2 August 11, 2009 03:35
Temperature instability with evaporating droplets. Owen FLUENT 0 November 6, 2005 23:16
