July 27, 2022, 13:19 |
Temperature Gradient of Fluid
Emilee Wissmach
Rep Power: 4 |
Is there a way to set up a temperature gradient of a fluid? I want my simulation to start with the water near the ocean floor colder than the surface water and see how it circulates once I introduce waves into the region.
July 29, 2022, 19:31 |
Carl Reilly
Rep Power: 16 |
yes, you can use the qsadd.f90 sub-routine to initialize the domain temperature (tn(ijk)) in the first iteration. i.e when iplace .eq. 0
If you review the Customizations section of the manual, and the sub-routine it should give you the information you require. |
Needt help about Soil Temperature Gradient Implementation | berkmm | FLUENT | 14 | May 7, 2020 17:40 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 06:46 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
