Home > Forums > Software User Forums > FLOW-3D
Interaction Between 2 Mesh Planes
Old   July 26, 2022, 10:45
Default Interaction Between 2 Mesh Planes
BRN
Sarp
BRN is on a distinguished road
Hello everyone, I have tried to simulate under water pipeline. I defined 2 mesh blocks. In mesh block one there is no event(just calm water) , in mesh block 2 I defined current velocity. When I saw the simulation I thought It was not reflecting the real sea condition, because ''velocity'' condition at sea did not affect the outside of the boundary at the beggining of the simulation.
Basically I would like to ask; which boundary layer should I select to make these two layers to interact with each other.
Thanks for your help
Kind regards,
BRN is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
