Can particles change the surface of fluid/surface |
Zhengxiao
Rep Power: 0 ![]() |
I want to simulate high speed gas to hit the water, if i use gas particles, can it change the shape of water surface?
particle surface |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 08:21 |
how to change the sizes of particles in the DPMFoam? | upc_ngh | OpenFOAM | 0 | September 29, 2019 00:21 |
Finding amount of particles that hit the surface of the object inside the flow path | Karnchat | FLUENT | 0 | March 16, 2018 05:18 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 05:27 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
