Home > Forums > Software User Forums > FLOW-3D
Baffle Flow Losses
Old   June 23, 2022, 09:15
Default Baffle Flow Losses
ale_sch is on a distinguished road
Hello. I have a doubt about the baffles.
The manual says: "The length L is set equal to the distance between pressure values located on either side of the baffle. At constant flow speed, u, this form ensures a fixed pressure drop, Delta p, across the baffle independent of mesh spacing: ..."
Does "constant flow speed" mean a flow speed independent on time?
ale_sch is offline   Reply With Quote
axial compressor mass flow convergence issue jyotir SU2 5 July 5, 2024 10:06
viscosity of fluid and impact on flow on a fixed supply line Henry04 Main CFD Forum 1 December 27, 2021 22:31
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
