May 22, 2022, 11:00 |
Adiabatic bubbles /Flow-3D
Rep Power: 4 |
Hi everyone,
Please, anyone can tell me what's wrong in this adiabatic bubbles model that i was built in Flow-3D (version 11.2) to show the flow of water and entapped air bubbles in pressurized tunnel of shaft spillway, that is does not work and running stop immediately. The dialog box of results displayed that the model has void region problems (zero or negative void pressure). More details of setting up parameters, physics tab and result dialog box of the model were attached in the image files below. I'm stuck... Thanks for any information Best regards Luqman Last edited by Othman; June 8, 2022 at 08:07. |
Contact bubbles with interface | sidoubouzareah | Fluent Multiphase | 0 | October 12, 2020 19:45 |
Adiabatic bubbles and f-packing | oajor | FLOW-3D | 0 | March 15, 2017 10:17 |
Random distribution of bubbles at the inlet? | petr.f. | OpenFOAM Running, Solving & CFD | 0 | December 5, 2012 02:41 |
Problems with non adiabatic PDF! | Christoph_84 | FLUENT | 0 | November 17, 2009 10:55 |
Bubbles in vertical pipeline | JM | Main CFD Forum | 1 | March 9, 2007 14:11 |
