Home > Forums > Software User Forums > FLOW-3D
Combustible Objects Help
Old   April 2, 2022, 00:23
Default Combustible Objects Help
Timothy
timinatorbttj is on a distinguished road
Hello all. I am looking to model the combustion of a solid propellant of AP/HTPB for a CubeSat. I have looked through the manual and I believe that I have set up the properties, but the pellet is still not igniting. I am trying to use a nichrome wire to start the ignition and have set those properties and the heat transfer up as well.
Is there a certain way to get the propellant to ignite that I have overlooked?
timinatorbttj is offline   Reply With Quote
Old   June 17, 2024, 11:36
Smile Have you solved the issue?
Aleksandr Mnatsakanyan
a.mnatsakanyan is on a distinguished road
Hey I seem to have the same issue where my component is not combusting.
If you have solved the issue could you please contact me a.mnatsakanyan@ufl.edu
I would be really grateful for the help!
a.mnatsakanyan is offline   Reply With Quote
combustible object, combustion
Multiple Floating Objects with 6DoF in OF 2.3.0 tyoung OpenFOAM Running, Solving & CFD 23 June 11, 2024 02:13
Run function objects on final time b.simpson OpenFOAM Post-Processing 3 September 19, 2022 21:09
Multiple floating objects using InterDyMFoam and sixDoFRigidBodyMotion solver FloatingSolar OpenFOAM Running, Solving & CFD 4 December 29, 2020 12:09
Update FOAM objects after new solver run peterTr OpenFOAM Programming & Development 1 May 11, 2017 17:26
[Other] mesh generation for sloping objects yuyingyuni ANSYS Meshing & Geometry 0 March 15, 2013 03:46
