How to choose ISO surface value for FAVOR geometry |
March 20, 2022, 13:35 |
Emilee Wissmach
Rep Power: 4 |
I wanted to see if anyone had a method/are there any standards for choosing the ISO surface value in the FAVOR tab. When I choose cell size for the mesh, I can base that on how many cells it will have to process and the associated run time, but right now I feel that I am basing my ISO surface value on what other FLOW 3D HYDRO examples chose and just how it visually renders.
Is there a better way to inform the choice of this value? Should it always be greater than the cell size? And should I be adjusting this value as I change cell size or keep it constant? I am doing submerged breakwater simulations, but my "breakwaters" are more heterogeneous than a typical one. Thank you! |
June 9, 2022, 06:06 |
KHALID EL ABBAOUI
Rep Power: 4 |
I have the same issue! Are there any suggestions please?
favor geometry, iso surface value |
[snappyHexMesh] Surface layers do not merge | mc6421 | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2023 03:00 |
sHM doesn't add layers to any surface | Vinzmann | Mesh Generation & Pre-Processing | 0 | March 23, 2021 05:02 |
[snappyHexMesh] Surface triangulation using snappyHexMesh | shaileshbg | OpenFOAM Meshing & Mesh Conversion | 4 | October 17, 2019 04:42 |
How To Create Fowcs William Hawkings Surface in Fluent? | marinkobezu | FLUENT | 7 | October 25, 2018 10:51 |
iso surface at a certain y+ | Adam | CFX | 1 | August 21, 2007 09:24 |
