Home > Forums > Software User Forums > FLOW-3D
How to show the distance travelled by the fluid?
Old   March 8, 2022, 23:58
Question How to show the distance travelled by the fluid?
Tom
mrtum3000 is on a distinguished road
I'm studying a flow which collapses on the slope as a result of an upstream dam-break, and I'm trying to find the distance travelled by the flow (i.e. 'shoreline position' or the 'surface run-up') but I can find no option for this in the 'general history' section of the 'probe' under the 'Analyze' tab.
The closest thing I can see is 'average distance travelled by fluid', but this is not what I'm looking for because it's an average. I'm looking for the shoreline position over time: it should produce a graph that rises and then falls.
Thanks.
mrtum3000 is offline   Reply With Quote
Old   March 15, 2022, 01:20
Sehroosh
MSM1985 is on a distinguished road
There is an option of distance travelled by fluid in 'Additional Output' for such purpose. Otherwise you can always use 'Distance Measuring Tool' in Flow Sight to approximately estimate a distance between to sections.
MSM1985 is offline   Reply With Quote
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Changing boundary condition Ux after fluid reaches a specific distance mcfdma OpenFOAM Programming & Development 2 November 21, 2019 04:52
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
