Home > Forums > Software User Forums > FLOW-3D
SWEs Model FLOW-3D
Old   March 8, 2022, 11:54
Default SWEs Model FLOW-3D
KHALID EL ABBAOUI
ELABBAOUI is on a distinguished road
Hello
Dear Members, I have a question
Can FLOW-3D solve Shallow Water with Saint-Venant Eqt or not. If yes, please how can we run a simulation with SWEs
ELABBAOUI is offline   Reply With Quote
Old   August 30, 2022, 11:13
UK
redlemon44 is on a distinguished road
The hybrid shallow water/3D flow model in FLOW-3D is designed to model flow around 3D structures within a ‘shallow water’ environment, such as bridges, drilling rigs at sea and dams in large reservoirs. The model uses multi-block meshing, where a mesh block is designated as shallow water or 3D. The standard shallow water or 3D equations are solved within each block, based on the user selection, and the respective solutions are coupled at the block boundaries.
https://www.flow3d.com/modeling-capa...water-3d-flow/
redlemon44 is offline   Reply With Quote
Model of air–steam flow with condensation into the volume and surface wall gartz89 Fluent UDF and Scheme Programming 0 February 10, 2022 00:26
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Enabling Open Channel Flow Sub-Model in Mixture model cod213 FLUENT 0 January 10, 2017 14:40
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 02:51
