Home > Forums > Software User Forums > FLOW-3D
Pressure instability
Old   February 18, 2022, 01:26
Post Pressure instability
Wenyu Zhao
Andrea-wwwwwwww is on a distinguished road
Hello everyone, I'm using FLOW3D to carry out the water entry test of the structure. The structure is set as a moving object, the coupling mode is turned on, and the measuring points are set on the structure to measure the pressure, but there will be many burrs in the obtained pressure, and the pressure measurement is very unstable. Do you have any good methods to deal with it?
Andrea-wwwwwwww is offline   Reply With Quote
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 07:33
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 19, 2018 00:39
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
