Home > Forums > Software User Forums > FLOW-3D
Roughness Raster File - Not Working
Old   February 1, 2022, 22:59
Default Roughness Raster File - Not Working
Atish
ati_d94 is on a distinguished road
Hi Forum,
I am currently trying to implement a non-uniform roughness into one of my simulations through the raster/ ascii import method. I am creating this file on python rather than eg. ArcGIS or CAD.
Importing the acsii file into F3D seems to work fine, as the layer appears within the GUI, however the roughness values are not being picked up by the model when running the simulation. As a test case, I am simulating flow in a channel where the channel bottom is created using a primitive. When trying to assign the roughness file to this component, the 'Roughness height raster' that needs to be ticked remains greyed out and I am not able to select it, does anyone have any advice on where I may be going wrong? Does the vertical position of the roughness layer matter?
I have attached my acsii and legend files below for reference (in text format), any help would be greatly appreciated
Kind regards
File Type: txt raster_legend_test.txt (32 Bytes, 2 views)
ati_d94 is offline   Reply With Quote
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
