January 23, 2022, 08:19 |
Upstream water depth
Ning Jing Hua
I have encountered a problem when I'm using shallow water model. Everytime I set up my upstream boundary condition by using specify fluid elevation (fluid distribution -> elevation type), the water depth result will be much smaller than the depth expected. For example, the fluid elevation input 81 m, the bed elevation is approximately 80m. But in the result analysis, the depth will become 0.1 m. I have tried everything to let the depth get bigger(ie. use velocity instead of flowrate; setup the initial condition...etc), but none of them work. I have no idea where the problem is and it's really frustrating. Can someone help me out? Thank you! |
water depth in two phase model | hm____reza | Fluent Multiphase | 0 | June 25, 2021 17:14 |
depth of water at 90% air concentration | zryan civil | CFX | 7 | August 15, 2016 08:39 |
VF to compute water depth in CFX post | yaseen wsu | CFX | 0 | June 17, 2016 03:24 |
a variable/expression to calculate water depth | hmasenger | CFX | 3 | January 31, 2015 17:46 |
Problem Patching Water Depth (2-D) | SEMC | FLUENT | 3 | March 15, 2004 20:58 |
