Home > Forums > Software User Forums > FLOW-3D
Questions about how to load the heatfl.f
Old   October 21, 2021, 09:33
Unhappy Questions about how to load the heatfl.f
wzr
wzrzainh is on a distinguished road
Hi,I wrote a function in heatfl.f about double ellipsoid heat source model,add
heat souce to fluid #1,but it dosen't work.I opened the udf interface,anyone can help me,please.
Is there something to set in the prepin.? or how to add boby heat source in qsadd.f ?
THANK YOU!
wzrzainh is offline   Reply With Quote
Old   October 22, 2021, 06:04
wzr
I modified the HEATFL.F like this
q=6*sqr3*dum12*dum13*exp(-3*(xi(i)-dum1)
1 *(xi(i)-dum1)/(dum14*dum14)-3*(yj(j)-dum2)*(yj(j)-dum2)
2 /(dum15*dum15)-3*(zk(k)-dum3)*(zk(k)-dum3)/(dum16*dum16))/
3 (dum15*dum15*dum16*pai*sqr314)
c q is heat flux about double ellispsoid heat source
heatfl1=q/dens
heatfl2=zero
is there any problem?I don't konw heatfl1's unit.Isn't J/(kg*s) ?
Heat flux is J/(m^2*s),how to get J/(kg*s)
who can help me?
Old   November 23, 2021, 04:39
koful is on a distinguished road
Hi.
Did you compile the source code? What kind of error did you get?
koful is offline   Reply With Quote
Old   November 24, 2021, 07:28
wzr
Originally Posted by koful View Post
Hi.
I have solved my problem.I'm confusing the unit of surface heat source and the body heat source.
Old   January 29, 2024, 06:51
Red face Gaussian heat flux code heatfl.F flow-3d
hamed
hamedsheikh is on a distinguished road
Hello
I have the same problem and I put the same code in Flow-3d version 11.0.4 software and replaced it. But the software does not read the code. I wanted to see if the problem is with the code or the software settings should be changed?
Can anyone help me?
hamedsheikh is offline   Reply With Quote
Solar Load and fvDOM Radiation Modeling Shadab_Ilahi OpenFOAM Running, Solving & CFD 14 August 28, 2024 08:11
remove static load in FSI analysis pi120 STAR-CCM+ 0 July 5, 2021 06:04
CFX parallel computing questions w784370882 CFX 3 January 1, 2019 01:40
So many questions in DPM & UDF - Help! URGENT! Prashanth FLUENT 0 March 3, 2009 23:26
Strarting load step number KtoTo Siemens 2 June 21, 2007 10:01
