September 30, 2021, 22:50 |
Questions about my Flow-3D work
F.
Have a nicE day. I have 2 question about my work.
First, How am I supposed to do the work of drawing water through the pipes? I'm using two methods, the second one doesn't work. Are they correct? 1. I make volume flow rate as mesh boundary condition and draw water in -z direction 2- I make wells in the shape of a circle (I define source and write negative flow rate) But I cannot draw water. Wells are under the pipes but you can see the water in the pipes Latter, I calculate an approximate flow rate from the colors, but how can I find out the exact flow rate through the pipes? Thanks in advance |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 11:40 |
How does the mass flow outlet BC work? | mvle | FLUENT | 0 | March 20, 2016 13:01 |
LES , fvScheme second order , free jet flow questions. | wenxu | OpenFOAM Running, Solving & CFD | 0 | November 19, 2014 06:59 |
some questions about nano fluids flow in microchannels | eeman | Fluent UDF and Scheme Programming | 0 | June 5, 2012 10:26 |
unsteady flow - matlab - for loop questions | Hooman | Main CFD Forum | 0 | September 5, 2011 20:03 |
