Home > Forums > Software User Forums > FLOW-3D
How to speed up the simulation of scour model in FLOW-3D?
Old   July 25, 2021, 23:38
Default How to speed up the simulation of scour model in FLOW-3D?
ZHANG H.
Unharuka is on a distinguished road
Hello everyone,
When I use the sediment scour model to do some simulation of a 3D pile, I found it was very very slowly although I use 16 processors, 32 processors, even 64 processors.
Maybe I generated too many meshes about 4 millions to 7 millions, because I found that the mesh size play a very important role in scour results. Now what I know is my cases run fastest with 24 processors, however it can only simulate 0.23 s in 1 hour reality.
It confused me for a long time, so if there are any solutions, please tell me, thank you very much.
Unharuka is offline   Reply With Quote
Old   December 7, 2021, 22:19
Default I have the same problem as you.
李涛
LT-ZJUT is on a distinguished road
Hello, I am a graduate student from Zhejiang University of Technology. I have the same problem as you. My flow-3D water and sediment two-phase simulation calculation is very slow, but the computer configuration is good, so I would like to ask if you have a solution.I would be most grateful if you could give me some advice.You can contact me at the following email address:taoli@zjut.edu.cn
LT-ZJUT is offline   Reply With Quote
Old   December 30, 2021, 04:48
koful is on a distinguished road
Hello.
Sedimentation models are very slow. but did you check sediment diameter to cell size ratio? your cell size should be more than 10 times bigger than the sediment diameter. choosing too fine mesh can cause extra long computation times.
koful is offline   Reply With Quote
how to set URANS turbulence model in unsteady flow simulation TimLiu OpenFOAM Pre-Processing 0 April 25, 2017 09:52
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 05:44
Simulation of cylinder aligned in the flow direction using k-e model Eliasjal FLUENT 2 June 13, 2012 09:00
turbulence model simulation in unsteady flow Chang Main CFD Forum 2 February 12, 2005 07:28
