May 23, 2021, 06:03 |
stl model cannot be scoured
Frankey
Rep Power: 5 |
Hello, everyone.
I’m currently doing sediment scouring. I have created a stl model to import. The properties of the model are set to packed sediment and the diameter is 0.001m. Meanwhile, the boundary conditions are set for fluid to enter from one side of the model and outflow from the other side. However, the simulation found that the volume of fluid 1 keeps decreasing, the model cannot be scoured, and the sediment content does not decrease but increases. I have tested the stl model with Magics and there is no problem. Have any experts encountered similar problems, please give me some suggestions and help. Thanks in advance |
sedimet scour with stl |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
How to create inlet/outlet/wall STL files from a STL CAD model | Gentible | Mesh Generation & Pre-Processing | 1 | June 23, 2015 11:18 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
Stl Model and Model after preprocessor are not the same !!! | AttaponC | FLOW-3D | 2 | October 1, 2009 00:54 |
