Home > Forums > Software User Forums > FLOW-3D
Solidified region interact with solid object
Old   March 10, 2021, 01:15
Default Solidified region interact with solid object
sneeringviper is on a distinguished road
I have a question. I have a cylinder thats solidified fluid region and I used a phantom object velocity to move it. The surrounding region is heating the solidfied region to melt it.
It is on a collision path with a wall.
The issue is that the solidified region does not interact with the wall and passes through it. However, the partially melted liquid stays behind.
How do I make the solidified region halt when contacting the wall?
Would using GMO help?
I have density, solidification, viscosity and gravity model active
Also anyway for gravity to act on solidified region?
sneeringviper is offline   Reply With Quote
How to implement radiation between a porous and a solid region in chtMultiRegionFoam? ThunderstruckGER OpenFOAM Running, Solving & CFD 1 November 17, 2023 00:00
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
alphat Wien3 OpenFOAM Running, Solving & CFD 22 August 15, 2019 11:00
non consistent wallHeatFlux from solid to liquid Kobi_Faust OpenFOAM Running, Solving & CFD 1 March 23, 2019 08:19
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
