March 9, 2021, 07:16 |
Customized heat distribution on STL-surface
Hi everybody,
since I am quite new to Flow-3D I am currently struggeling to accomplish to following task: My goal is to implement a heat source into a simulation that is defined on the surface of a stl-geometry that I want to import into Flow-3D. The heat distribution is defined at each vertex of the STL-model so you could think of the vertices as vectors of length 4 instead of length 3 where the 4th entry is now the heat. I am aware that I have to use the customizable fortran files and I already read the documentation but I could not figure out how to read the vertices of the imported stl-geometry and furthermore how to assign them the desired heat input. So what I would actually like to do is:
So does anybody already have experience with a similar setup and tell me if my approach is right. Or could anybody tell me how to access the vertices and identify them with the vertices of the original stl-file? I'm looking forward to any helpful answers. Thank you in advance, David Last edited by David226; March 9, 2021 at 07:25. Reason: Grammar mistakes |
March 22, 2021, 07:34 |
Rep Power: 12 |
Hi David. Did you checked the heatob.f90 file? It should have some explanation in it. Does heat source distribution uniform for the hole surface?
(ijk) is the cell identifier for the flow3d. ijksd gives you solid domain. |
custom heat input, heat distribution, heat source, stl, stl-format |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Conjugate heat transfer with radiation heat loss from solid surface | Faizan89 | Fluent UDF and Scheme Programming | 3 | April 9, 2020 13:46 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
CEL expression for calculating heat flux to be applied as surface boundary condition | shadnia | CFX | 14 | August 20, 2018 18:32 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
