February 27, 2021, 18:00 |
Problem when importing .ASC file to FLOW-3D
After watching the FLOW-3D on-demand videos, I'm trying to run my own model for the first time: a dam break simulation. My goal is to get the outflow hidrograph at the dam breach.
For the topography, I tried to import an .ASC created in QGIS from a GeoTIFF file I previously had. No error message is displayed and the STL file is apparently created. However, no solid surface is displayed in the model setup, even if I use the "fit to screen" button. The x, y and z axes also disappeared. Does anyone know what's going on? |
February 27, 2021, 18:18 |
Eric Lemont
Rep Power: 6 |
I've experienced a delay before when loading larger ASC files. On a recent model, my ASC was over 300MB and it took a minute or two for the ASC to show up after loading into the component list. One thing to check is the bottom right part of the display window and see if you notice a status bar with "some task" shown in the title.
February 27, 2021, 18:27 |
#3 | |
Thanks for the reply, though! |
March 22, 2021, 07:18 |
Rep Power: 12 |
asc files were imported as a surface. you can check the extents at the min/max menu from subcomponent's properties. Maybe after creating a mesh and FAVOR, your geometry can appear. Otherwise the file is broken most probably. Did you try to open the geometry with another software?
May 6, 2021, 05:54 |
Kaushik
Rep Power: 17 |
When you create *.asc from QGIS, it some scales the values. So when you import the geometry in FLOW-3D, you will need to do a scaling or magnification. This should help you see the geometry. you may see the limiters value to help you know if there is a geometry imported.
February 21, 2023, 11:21 |
Are your ASC coordinates in degrees?
SKM
I faced the same issue as you. After importing my ASC file and a couple of clicks (toggling layer visibility) in Flow-3D, a dot appeared, which I carefully zoomed into and realized that the X & Y are too small to be rendered well compared to Z.
The problem was the ASC file was generated in decimal degrees with a very small cellsize (~10^-5), but as ASC does not have projection information, it was being considered literally in Flow-3D. Upon editing the ASC file (right click and open with Notepad/ Notepad++) X & Y limits and cellsize according to the dataset, the ASC file is visible in Flow-3D as expected. |
asc, flow-3d, problem |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
