Home > Forums > Software User Forums > FLOW-3D
Drag forces on piers
Old   January 14, 2021, 12:52
Default Drag forces on piers
Elpida Panagiotatou
Hopito is on a distinguished road
Hello everyone,
I am using flow 3d in order to calculate the drag force exerted on a pier.
In order to do that I load an stl file with the pier and then I click on subcomponents -> component properties ->output -> pressure and shear force output.
When I try to calculate drag force from the momentum balance equation I get a different result from the one I get from Flow3d.
Does anyone know what is the pressure force output and how it is calculated on Flow3d?
Note that for the run i use pressure -> hydrostatic pressure in z direction
Hopito is offline   Reply With Quote
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
Residuals and forces spiraling out of control before failing edomalley1 OpenFOAM Running, Solving & CFD 3 September 7, 2018 11:42
Negative drag forces of fanwing airfoil vkid185 OpenFOAM Post-Processing 0 March 26, 2017 08:16
How to write the drag forces and separate it into viscosity drag and pressure drag Joanna Huang OpenFOAM Post-Processing 0 January 7, 2013 12:37
