How to change the viscosity of STL-fluid Region in initial condition |
Md Tusher Mollah
Rep Power: 0 ![]() |
Hi All,
I am using fluid STL geometry in the 'Regions' of the 'Initial condition' part of Flow-3D. I want to use a different viscosity for that STL fluid geometry apart from the global one. How can I make this change? If I need to customize the solver, where can I make this change? Thank you in advance. |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
How I can introduce my power heat (W) in chtMultiRegionFoam? | aminem | OpenFOAM Pre-Processing | 32 | August 29, 2019 02:23 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
