August 10, 2020, 13:23 |
open channel BC
saphana
Rep Power: 6 |
hello all,
can i make simulation by flow3d for open channel flow if only volume flow rate(m^3/s) existing ? i want your advice for which one is better to deal with roughness and porose zone simulation flow3d or fluent thanks |
August 10, 2020, 19:21 |
Eric Lemont
Rep Power: 6 |
Yes - FLOW-3D specialises in modelling open channel, free-surface flow conditions. If you have a volume flow rate boundary, there are a few ways of specifying the initial flow depth in the channel. There are also a few options for specifying roughness in the model.
August 11, 2020, 05:43 |
saphana
Rep Power: 6 |
so you mean i need also to specify initial depth to complete the simulation.
But if the initial depth is not known, can I complete the simulation? regarding roughness if there is coarse gravel on channel bed how can i represented it in flow3d ? and kindly could you tell me what experimental parameters i need to represent it either porose media or rough bed |
August 11, 2020, 09:22 |
Eric Lemont
Rep Power: 6 |
You don’t need to specify a depth. You can just have an initially empty channel and a free flowing outlet condition if that’s what you are interested in.
You can specify different surface roughness values for different components in the model. You can assign a roughness value similar to gravel for the bed. You could model porous media as well. There are a few ways to account for flow behaviour through porous materials. It’s hard to be more specific without knowing more details or the desired outcomes from your modelling. |
August 11, 2020, 10:18 |
saphana
Rep Power: 6 |
thanks a lot ,can i send you the details on your email if possible
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 14:40 |
Open Channel Boundary Conditions Issues | Env | FLUENT | 8 | June 28, 2016 17:05 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 12:44 |
