modeling droplet falling to the bottom problem? |
June 16, 2020, 04:31 |
VincentDamian
Hi, I'm trying to figure out which setting is necessary to simulating droplet behavior properly, which is a simple droplet falling toward the flat surface, for practice.
I applied gravity, surface tension and viscous flow modules. What I thought is that the droplet is broken into small particles and splashed in all directions after the impaction of the droplet with the bottom side, but the simulation result is that the droplet is just spread on the bottom side, coated thinly until it arrives at the mesh boundary. (I didn't set boundary condition as I'm just interested in droplet splashing part) Is there anyone who can guess the reason for this phenomena or point out what I thought improperly, it would be a great help for me and I appreciate. |
June 18, 2020, 18:33 |
#2 | |
John Ditter
Rep Power: 11 |
If the droplet has sufficient velocity relative to the restoring forces of surface tension and viscosity, the simulation should indeed show droplet breakup. It will be helpful to compute relevant non-dimensional parameters such as the Weber number and the Bond number to gauge the relative importance of the physical properties. It sounds like the viscosity of the droplet is very high. Or possibly the surface tension coefficient is too low? John |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
modeling droplet falling to the bottom problem | TimLim | FLOW-3D | 1 | June 15, 2018 18:03 |
modeling vaporization droplet | iqbal1990 | STAR-CCM+ | 11 | March 26, 2014 10:13 |
2D VOF Droplet evaporation model. Multi-component problem | nb92 | Fluent Multiphase | 0 | February 28, 2014 11:36 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
