Pressure iteration did not converge in scour simulation |
June 7, 2020, 23:04 |
MAI THI LOAN
Rep Power: 6 |
Hello everyone,
I am writing here to receive your help. I am simulating sour sediment over the cylinder. The simulation with a cylinder at 90 degrees is good. However, when I change the cylinder with 80,70,...30 degrees, the solution does not correct and it said that "pressure iteration did not converge in itmax= 100 iterations". After that, the solution is stopped. I changed the value at multiplier for dynamically adjusted convergence criterion which in pressure solver options>>convergence controls to 100 and 10^6, but that situation continuously occurs. Please help me explain and solve this problem. Thank you in advance. |
June 9, 2020, 12:01 |
nazrin
Rep Power: 10 |
Hi Mai Loan,
Try to improve your mesh. Use nested block or confirming mesh. Refer the manual for more information. |
Calculating pressure coefficient on surface of an object in ABL simulation | faiazk | OpenFOAM Running, Solving & CFD | 7 | July 25, 2019 21:07 |
Bearing simulation outlet pressure | Tierce | CFX | 1 | October 31, 2018 17:00 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 21:05 |
Pressure dissipation problem in bubble simulation (Riemann problem) | ndabir | CFX | 9 | June 4, 2015 17:48 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
