May 28, 2020, 04:57 |
coupled motion object
Tom
Hello,everyone I am a newbie in flow-3d.
My question is about a box (the volume is about 200mm*150mm*47mm)filled with mortar.And I add some fiber(material:steel ,diameter: 0.38mm length: 30mm) into the box.I set the object is coupled motion and I sure the mesh include the volume. but I try many times it always display: 1)surface area/volume for moving component 2 is zero . 2)calculated mass or moment of inertia tensor is not correct,make sure the moving object is inside the domain and the input data for mass property are correct. hope anyone can help me the problem I was confuse for days. Thank you very much! |
error in fireFoam, when running the case wallFireSpread2D | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 9 | February 1, 2018 19:45 |
Including dynamic mesh and motion of object in waves2Foam | PVERMA | OpenFOAM Running, Solving & CFD | 0 | November 10, 2017 03:06 |
DFBI Morphing for roll and heave motion | Lingfeng Su | STAR-CCM+ | 0 | November 10, 2015 08:08 |
External management of solid motion (using dynamicmesh) | maxou1993 | Main CFD Forum | 0 | July 28, 2015 12:37 |
Prescribed object motion and 6DOF | vinz | OpenFOAM Running, Solving & CFD | 1 | September 23, 2013 08:37 |
