Home > Forums > Software User Forums > FLOW-3D
Flow Depth and Flow Constant
Old   April 25, 2020, 19:00
Default Flow Depth and Flow Constant
Alex
alex_marcelo878 is on a distinguished road
I work with different waves, my problem with flow-3d is that it cannot keep the mean fluid depth constant it starts increasing or decreasing after awhile. I tried so many different things, but I couldn't figure it out how to keep it constant. any thoughts?
alex_marcelo878 is offline   Reply With Quote
Old   April 27, 2020, 03:54
nazrin
M.Nazrin is on a distinguished road
hi Alex,
Do you have any object in ur simulation? If yes, what can i advise u right now is to start ur simulation as simple as possible. For example, start with proper domain size and your wave data. the simulation should not have any object for the user (in this case, yourself) to get general idea. If the wave modelled properly, then add complexity (meshing, object etc) in your simulation.
M.Nazrin is offline   Reply With Quote
Flow depth variation problems er_anas FLUENT 1 April 6, 2020 07:08
Flow Depth in VOF open channel flow akjha Main CFD Forum 3 November 5, 2015 04:07
flow depth in channel mahdi1 FLOW-3D 5 May 30, 2013 06:28
flow depth in 2D open channel ? rodi FLUENT 7 January 26, 2011 00:03
Default Depth of 2d Flow M-Ray FLUENT 0 May 20, 2008 04:10
