Home > Forums > Software User Forums > FLOW-3D
Error when applying the Gaussian heat source
Old   December 5, 2019, 22:37
Default Error when applying the Gaussian heat source
Zeqi Hu
lanran214 is on a distinguished road
Hi, everyone:
For the welding simulation, I want to apply a Gaussian heat flux on the free surface cells. I modified the rhoe(ijk) density*specific of the free surface cells in the qsadd.F90 subrutine, the temperature could increased correctly at first several seconds, but when the temperature exceeded the melting point, the solver run into an error, the time step and stability limit was not stable, and the fluid even disappeared in the 3-D postprocess interface, what's wrong with it?
Sometimes it shows the error message: heat transfer/conduction flux exceeded stability limit.
Is the error caused by the frees surface cells? and why the error occurred when the temperature exceed the melting point exactly?
Thank you.
lanran214 is offline   Reply With Quote
Old   December 15, 2019, 16:50
Default notsureitrightornot
Xuesong
xuesong is on a distinguished road
I think you can try a two-fluid simulation. The one fluid with void is less physical, maybe there's some uncovered technical details.
---- 2020.12.31-----
I find i didn't activate the surface tension model. Now it works with one fluid with surface tension model on. There's no negative temperature error occurred.
xuesong is offline   Reply With Quote
welding simulation
Heat source on the surface of the wall Vishsel OpenFOAM Running, Solving & CFD 2 April 27, 2020 10:59
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
