October 9, 2019, 22:25 |
Shift Axis/Coordinate Range
Gaby
Does anyone know how to shift the x-axis on FlowSite? This is not for a plot, but for the axis on the main viewport (when you right click>modify>bounds tab> under "General" check "Visible).
My geometry's origin is at (27,0,0) and I would like to shift it to (-3,0,0). I have tried modifying the "Coordinate" variable found in the "Variables" table that pops up when you click the "Calculator Tool Box" button. I am unable to change the range, which is currently set at [27, 36.5]. Also, is it possible to add an axis title? Any information is much appreciated. |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
AMI memory leak? | MichiB | OpenFOAM Programming & Development | 14 | August 1, 2015 19:18 |
[General] "Data range too small to render" | mangj | ParaView | 0 | July 1, 2014 19:24 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
unexpected range in pressure level CFD-Post | stefank | CFX | 4 | February 2, 2011 06:27 |
