Home > Forums > Software User Forums > FLOW-3D
Pressure iteration diverging problem
Old   July 22, 2019, 03:41
Unhappy Pressure iteration diverging problem
Lim Xue Yen
xueyen is on a distinguished road
Hi, i am running a simulation of ship maneuvering that attached with rudder.
Hull was applied with force x-axis while rudder applied with angular velocity at z-axis.
When running the simulation it shows pressure iteration diverging and simulation stops. What is the problems causing this?
when without rudder the simulation can be done but after attached with rudder it shows this problem.
Any advice to this problem? Thank you.
xueyen is offline   Reply With Quote
Old   July 29, 2019, 14:07
thunde47
thunde47 is on a distinguished road
Try the following in the Convergence Controls window of the Pressure solver options in the numerics tab:
1. Increase the maximum number of pressure iteration
2. Increase the dynamically adjusted convergence criterion
3. Try both 1 and 2 together
4. Increase the GMRES subspace size
thunde47 is offline   Reply With Quote
Pressure Problem with G-equation in CFX Esamor CFX 2 September 10, 2018 19:35
Low pressure inlet problem Bisht FLUENT 10 March 28, 2018 10:04
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 02:54
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
