Piano key weir with parapet simualtion problem |
June 8, 2019, 04:48 |
Tuan
Rep Power: 7 |
Hi everyone,
Anyone here has tried to simulate the hydraulic behavior of piano key weir? I have a problem with meshing the parapet wall on the crest of PKW. Its size is completely small compring to other parts of weir (keys, side walls, etc.) so I dont want to choose a too refined mesh for all components for a good FAVORized parapet wall because it will lead to enormous amount of cells in simulation. Any advice for a good result? Thank you very much. Last edited by x6102104; June 9, 2019 at 00:14. |
meshing, pkw |
Problem diverges when exhaust valve opens | swerner0711 | AVL FIRE | 0 | September 21, 2018 07:14 |
Problem to run simpleFoam using qsub? | be_inspired | OpenFOAM | 1 | December 22, 2015 12:53 |
problem when simulating overflow at a sharp-crested weir | Ya_Squall2010 | OpenFOAM | 2 | January 9, 2013 17:26 |
[snappyHexMesh] Problem Meshing a V-notch Weir with snappyHexMesh | kflora | OpenFOAM Meshing & Mesh Conversion | 11 | December 19, 2011 01:58 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
