May 27, 2019, 15:22 |
Depth average velocity/velocity seleced
USAMA MAJEED
If I use average depth velocity then obviously it will be less velocity and length of jump will be very small. Can I use velocity in lower region of stilling basin instead of depth average velocity to have better match with physical model. Velocity in green region below blue region is much higher than upper region. I have attached screenshot below:
Thanks in advance |
May 28, 2019, 03:34 |
Sehroosh
Rep Power: 7 |
Depth average velocity are faster in deep area and shallower in lower areas. Check both velocities: Depth averaged velocity and horizontal velocity component. Whichever gives close approximation to physical model observation, use that velocity component.
May 28, 2019, 10:48 |
USAMA MAJEED
thanks very much. If i use maximum velocity along length of region it give close results to physical model or i use horizontal component which will be negstive due to formation of rollers st the start of jump.
May 29, 2019, 01:29 |
Sehroosh
Rep Power: 7 |
-ve velocity is due to reverse eddies/rollers in the hydraulic jump due to turbulence. If you need the velocity entering into the jump, use velocity before this turbulence region and that region might be at chute of the spillway. You can use either depth average velocity or horizontal velocity component, whichever is close to physical modeling.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 06:37 |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 22:51 |
Average Facet, Surface Vertex or Area-Weighted | Emmanuel | FLUENT | 3 | March 27, 2020 11:55 |
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? | rsin | CFX | 19 | December 29, 2018 05:43 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
