April 21, 2019, 17:41 |
using Fluent or Flow-3D
sobhan
Rep Power: 8 |
hello All Users
I want to study the 3D flow structures of a solitary wave propagating over a submerge porous barrier using LES Model. Which software do you recommend?FLUENT or FLOW3D? Does anyone have any experience at this mater? Which one gives better results for solitary wave generation and Multi-phase+VOF method? Thanks in advance. |
May 17, 2019, 20:31 |
Rep Power: 9 |
Hi Sobhan,
I've worked with both Fluent and Flow3D. However, I don't have experience in this case (solitary wave propagation). Generally Fluent have way more sophisticated multiphase and turbulence models, but it is numerically expensive. A free surface simulation that takes a few hours to be solved by Flow3D might take days to be solved by Fluent. If you have access to HPC, Fluent would be better. If not F3D makes more sense. Cheers, Farzam |
June 24, 2019, 19:31 |
FLOW-3D has been used to perform similar studies in the past. We have a dedicated waves module with an option for different waves propagation.
Of course, like others pointed out, free surface tracking is the known strength of FLOW-3D. Additionally, we have a porous media option and inbuilt LES model as well. I do not know about ANSYS but FLOW-3D seems like a good option. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Fluent v15 multiphase flow b.c. failure Non-channel flow | mickjazz | Fluent Multiphase | 1 | September 22, 2014 07:41 |
help for ANSYS Fluent - cylindrical flow | slimmsk | ANSYS | 0 | April 17, 2012 18:00 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
