Home > Forums > Software User Forums > FLOW-3D
Sediment Scour in Shallow Water
Old   February 21, 2019, 09:50
Default Sediment Scour in Shallow Water
siamakkhayyatrostami's Avatar
Siamak Khayyat Rostami
siamakkhayyatrostami is on a distinguished road
hi
i am trying to model Sediment Scour in Shallow Water in flow-3D, the example of software has this topography component in format of .inp , which contains facet normal and vertexes coordinate in order of "X" "Y" "Z" and even with one cell in z direction software recognizes component finely, i used Topo2STL utility of flow-3d to create my own topography from a "XYZ" grid file which results in facet normal and vertexes coordinate contained .stl file. so far like example, flow 3d can recognizes my component even with one cell in z direction, i define this component as sediment packed, after one time step of simulation my topography is vanishing and water surface is adjusting itself with the floor of my mesh block, ignoring the topography (shallow water mesh block and physic is active). does Sediment Scour in Shallow Water in flow-3D work only with .inp format for component?
(i defined bed load coefficient and entrainment coefficient equal to zero to prevent sediment scour, but it didn't work too and component is ignored)
siamakkhayyatrostami is offline   Reply With Quote
flow 3d, inp, scour, sediment, shallow water
Shallow Water Equations: Roe Approximate Solver First-Order with Wetting-Drying mhallsmoore Main CFD Forum 2 December 20, 2016 14:50
scour sediment model javadrasooli FLOW-3D 2 May 15, 2015 13:23
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Looking for "numerical methods for shallow water flows" book novan tofany Lounge 0 February 10, 2011 19:28
FVM on Unstructured grids for shallow water flows WLH Main CFD Forum 0 June 15, 2005 09:48
