Patrícia Lima
Rep Power: 8 ![]() |
I'm working with Flow-3d since january, but in the last month all simulations are taking a really long time to process, even the ones i did before in a smaller time. Does anyone know what is the problem ??
Are you still using the same number of processors as before? Did you by mistake change the number of processors to be used?
Use CTRL + E to open the prepin file in the GUI. Then search for nprocs variable. See if that is set to the same number as before. |
Patrícia Lima
Yes, i didn't change de number os processors, and i can't figure this out .
flow-3d, process, time |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
Time Step Continuity Errors simpleFoam | Dorian1504 | OpenFOAM Running, Solving & CFD | 1 | October 9, 2022 09:23 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
