Home > Forums > Software User Forums > FLOW-3D
Modelling Turbine flow
Old   November 27, 2018, 07:49
Exclamation Modelling Turbine flow
Stephan
Ste3D is on a distinguished road
I'm modelling a river power plant including weir and turbine passage. The turbine runners itselfe are not represented in the model, however I account for the turbine and flow distributor resistance using baffle losses. The volume flow rates through the turbines are correct, but I observe a strange pattern regarding flow velocities resulting in a very inhomogeneous flow field, which cannot be not be observed by measurements. The figure shows the model flow velocities 12m downstream of the "turbine".
Figure of flow velocities
has someone observed a similar pattern and might have an explanation for it? I use the RNG turbulence model. Grid resolution is 0.5m (x,y,z) with 0.25m conforming mesh to blocked volume. Already tried without conforming mesh (0.25m for whole tubine passage) thats not the reason for the observed pattern.
Thanks for your help!
Ste3D is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 06:16
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
flow in gas turbine Abdul Hafid Main CFD Forum 1 September 14, 1998 10:39
