Home > Forums > Software User Forums > FLOW-3D
3D geometry & FAVOR
Old   August 26, 2018, 06:32
Default 3D geometry & FAVOR
hkja3A is on a distinguished road
3D geometry was created in AUTOCAD platform. But when I use FAVOR button in Flow-3D software, the 3D geometry appear incomplete and partially missing. Does anyone can solve this problem and give several suggestions? How can I adjust the mesh so as to make the overall geometry show? I’ll appreciate it.
hkja3A is offline   Reply With Quote
Old   September 1, 2018, 10:48
Pankaj Lawande
pankajl is on a distinguished road
You could see incomplete and or partially missing geometry if you have inadequate mesh. Couple of remedies
1. Right on mesh block > fit to geometry
2. Refining the mesh
Combination of these two solve your issue. If the issue still persists, could you please share the geometry and input file?
pankajl is offline   Reply With Quote
Old   September 3, 2018, 21:59
Thank you for your reply.The issue has been resolved as your suggestions. Many thanks.
Old   September 4, 2018, 06:47
Ahmed M Helmi
AHMEDHELMI is on a distinguished road
If small elements exist in the domain you can use multiple block instead of refinement the mesh for the whole domain
AHMEDHELMI is offline   Reply With Quote
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 14:02
How to scale and translate the grid of particle data and STL geometry Saidul Tecplot 1 January 11, 2015 22:15
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
