Home > Forums > Software User Forums > FLOW-3D
gravity in cylindrical mesh
Old   July 10, 2018, 04:48
Post gravity in cylindrical mesh
Atiieh Rostami
ati_ros61 is on a distinguished road
hi dears
I want to model a horizontal pipe in Flow-3d with cylindrical mesh block. I have a problem with a definition of gravity. as z-direction is the direction of the pipe, how can I define gravity appropriately?
I applied: non-inertial reference fram=>in "initial gravity" set "y-component" as "-9.81"
but doesn't work
ati_ros61 is offline   Reply With Quote
Old   August 22, 2018, 14:26
thunde47
thunde47 is on a distinguished road
In cylindrical coordinates, the axes are r, theta, and z. If you apply gravity in the y-direction, the solver will, in fact, apply it in the theta direction. What that means is that you will end up applying angular acceleration causing Euler forces instead of gravitational force.
In cylindrical coordinates, it makes sense to apply gravity in the z-direction. If your pipe's orientation requires gravity to be applied in some other direction, please use cartesian coordinates.
thunde47 is offline   Reply With Quote
Old   October 4, 2018, 12:45
Martin Liepe
MartinOVGU is on a distinguished road
Originally Posted by ati_ros61 View Post
hi dears
but doesn't work
This should work.
I had similar parameters in a casting process:
Horizontal "pipe" with cylindrical mesh. x-direction marks radius, y- marks theta and z- marks length.
(No values in "shake and spin model")
Worked pretty well. No angular gravity but constant in y-direction...
MartinOVGU is offline   Reply With Quote
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 06:03
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
setfileds for cylindrical mesh aki_yafuji OpenFOAM 3 December 9, 2010 22:35
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
