Home > Forums > Software User Forums > FLOW-3D
Slug-ft-s Pressure Units
Old   May 24, 2018, 18:36
Default Slug-ft-s Pressure Units
William E. Seychew
Will S is on a distinguished road
I've spent more than an hour searching for an answer so thought I'd better ask other users. Selecting these units for the model, I'd assume the output pressure units should be pounds per square foot. When I looked at the pressures in my model, they are astoundingly too high (or negative). I then thought it was because the pressures are absolute rather than gauge...still astoundingly high (and some impossible negative). It also switches from positive to negative within one cell block, with no transition. Am I missing something here, or is my model just broken?
Some of my data....
The visualizations of the model and all other outputs seem reasonable. I just don't get it. Any ideas?
x y z p v hyfd
271.75 205.66264 752.25 -547217.38 1.8042365 8.3300419
272.25 205.66264 752.25 -540091.69 1.5180495 8.3300419
272.75 205.66264 752.25 -532619.38 1.3160932 8.3300419
273.25 205.66264 752.25 -525889.5 1.1408727 8.3300419
273.75 205.66264 752.25 -520472.59 0.93963432 8.3300419
274.25 205.66264 752.25 -516046.25 0.69941252 8.3300419
274.75 205.66264 752.25 -512142.38 0.47867304 8.3300419
275.25 205.66264 752.25 -508268.88 0.33344299 8.3300419
275.75 205.66264 752.25 -504521.06 0.2240238 8.3300419
276.25 205.66264 752.25 -500844.69 0.10055891 8.3300419
276.75 205.66264 752.25 497331.03 0.036355048 8.3300419
277.25 205.66264 752.25 493956.66 0.18747687 8.3300419
277.75 205.66264 752.25 490864.31 0.34542078 8.3300419
278.25 205.66264 752.25 487967.06 0.50996113 8.3300419
278.75 205.66264 752.25 485164.44 0.67545855 8.3300419
Will S is offline   Reply With Quote
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Pressure units in incompressible solvers Per OpenFOAM Running, Solving & CFD 4 July 19, 2019 04:43
Pressure Inlet Boundary Conditions Mr.Goodcat FLUENT 5 June 20, 2019 02:47
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
