Home > Forums > Software User Forums > FLOW-3D
Inclined GMO
Old   April 20, 2018, 05:38
Default Inclined GMO
George Klironomos is on a distinguished road
Hi to all Flow 3-d users.
For my thesis i am modeling an inclined archimedes turbine but i have problem defining right the coordinates so the turbine is not moving.
In an other case, i was able to rotate the frame through the gravity components but now the turbine is modelled with other components and i cannot do that.
I have already tried 6 degrees of freedom with only the axis am interested set to coupled and the other prescribed (o) but with no good result.
How can i define right an inclined fixed axis?
Thanks in advance for your replies..!
George Klironomos is offline   Reply With Quote
gmo, inclined axis, moving component, turbine
GMO suddenly can not move! yongticle FLOW-3D 1 February 5, 2018 14:23
Water flow in inclined plate Ashke Fluent Multiphase 0 April 30, 2015 05:08
[snappyHexMesh] inclined jet modeling simonsg OpenFOAM Meshing & Mesh Conversion 0 March 17, 2014 02:22
NACA - Inclined flow / symmetryPlane SD@TUB OpenFOAM Running, Solving & CFD 0 January 21, 2010 03:47
about GMO and STL edward FLOW-3D 4 March 24, 2009 12:20
