April 3, 2018, 08:59 |
Existing simulation
Guillermo
Rep Power: 8 |
I want to create a new simulation from a previous one, just changing some parameters. i know I need to copy the preping file and change the name, also the STL file, some other file?
April 13, 2018, 20:32 |
Ideally, you should be able to create a simulation copy from the GUI itself. But in case you want to do it manually from directories, you may consider moving movin.inp files as well, if they exist.
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 06:55 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 17:06 |
Axial fan simulation in UG/NX 7.5 | fan123 | Main CFD Forum | 2 | April 23, 2011 09:22 |
