March 24, 2018, 03:31 |
Heron Fountain Simulation
Hamed Sajjadi
Hi every body!
i am trying to have a very simple 2D simulation of Heron Fountain. my problem is that i want the air to exert pressure on water and makes it to move up but it doesn't happen i activated "2 Fluids" but "Incompressible". and in physics tab: Density evaluation Gravity viscosity and Turbulence two fluids are loaded. and in initial window; i defined a region that fills the domain with fluid with a fraction of 0, which is air , and after that i defined 3 other regions of water, friction =1, as was described in Wikipedia. and solver gives me this messages: pressure iteration did not converge in itmax= 200 iterations at time= 6.93363E-02 cycle= 1 iter= 200 delt= 6.93363E-02 epsi= 1.298E-03 maximum residual= 3.153E+01 at i= 21 j= 12 k= 2 block= 1 restarting cycle with smaller time-step size present relaxation factor omega= 2.000E+00 present time-step size delt= 6.934E-02 and also dt<dtmin when i rendered results, the water is acting weird? do you have any suggestions? i simulated this fountain by Water-Oil with the same settings and it seems to be alright but i have those issues by Water-Air. |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
How to set unsteady turbulent inlet velocity using the result of another simulation? | John-Lee | FLUENT | 2 | December 27, 2016 18:36 |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 06:55 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
