February 23, 2018, 06:05 |
Nested blocks bug?
Hello. I'm doing ship simulation with 3 nested blocks. Two inside blocks are with grid overlay BC, outside block are with symmetry BC and Specified velocity BC ant at the front and back. With laminar model i get different flow speeds at free surface in the inside block (see attached pictures). With turbulence model (RNG) i get diferent speed at the fluid surface in the biggest block (see attached pictures). i'm fearing that it can distort resistance results. Any ideas how to fix it?
block, block interaction, nested blocks, ship simulation |
[Commercial meshers] fluent3DMeshToFoam | bego | OpenFOAM Meshing & Mesh Conversion | 31 | August 16, 2023 10:04 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 04:13 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 11:45 |
