Flow 3D Cast simulation Error: Fluid volume error exceeds 5% |
August 1, 2017, 13:03 |
Santosh Reddy
Rep Power: 9 |
In many of my simulations in Flow 3D Cast, I am observing following error and mentor tip but I have no idea how to implement the suggested changes. Any kind of help to solve this issue is appreciated.
convective flux exceeded stability limit at t= 5.0192E-03 cycle= 26 iter= 17 delt= 2.7720E-04 mesh block 1 restarting cycle with smaller time step 3.02227E-02 163 2.32E-04 2.32E-04/cz 6 4.57E-01 5.9800E-06 +1.83E-01 0.02 0.0000E+00 0.00 00:00:07 94 11:57:45 00:08:04 6.04859E-02 277 3.29E-04 3.29E-04/cz 4 5.67E-01 1.1609E-05 +2.11E+00 0.03 0.0000E+00 0.00 00:00:10 87 11:57:48 00:06:08 9.05542E-02 368 3.53E-04 3.53E-04/cz 9 7.92E-01 1.6953E-05 +4.40E+00 0.04 0.0000E+00 0.00 00:00:13 90 11:57:51 00:05:33 ============= mentor tip =============== fluid volume error exceeds 5%. 1. tighten convergence epsadj. 2. reduce time-step size tdtmax. 3. reduce rcsql compressibility. 4. is there excessive fluid break up? ======================================== TIA |
November 30, 2018, 03:41 |
Alex
Rep Power: 9 |
The same problem-_-||
Have you solved it yet? |
December 13, 2018, 12:58 |
Well, try doing what the mentor tip recommends. You can change the epsadj parameter in the numerics tab under the convergence controls for pressure solver options. epsadj corresponds to the multiplier for dynamically adjusted convergence criterion.
convective flux, flow 3d cast, volume error |
Is it possible that multi-phase flow shows gradation of volume fraction? | kjh9537 | Fluent UDF and Scheme Programming | 0 | June 23, 2017 15:16 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
difficulty on how to implement shot sleeve simulation in flow 3d cast | ankur singh | FLOW-3D | 10 | April 6, 2015 11:34 |
two fluid, volumetric/mass flow rate at different volume fractions | Veronique Pe | CFX | 2 | November 26, 2014 06:30 |
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit | coompressor | OpenFOAM Installation | 0 | November 12, 2008 20:53 |
