Initial pressure conditions for metal input in Flow 3D Cast |
July 26, 2017, 23:05 |
Santosh Reddy
Rep Power: 9 |
Is there any way that we can apply pressure conditions to the initial metal input in Flow 3D Cast?
This condition is required as I am trying to model an experimental result from a paper where the authors poured metal that is of 350Pa from the top of pouring basin. I couldn't find any workable way to implement the same in Flow 3D Cast. |
July 29, 2017, 11:23 |
Zahra Mehrad
Rep Power: 9 |
Model setup--> Meshing & Geometry --> Initial--> Global--> Presure--> Uniform Presure and then enter the presure value.
July 29, 2017, 19:15 |
Santosh Reddy
Rep Power: 9 |
Thanks for answering but I couldn't find any section with the name "Meshing & Geometry" in Flow 3D Cast. There are sections with the name "Meshing" and "Geometry" independently and I can't find the "Initial" option in either of them. Just to remind, I am concerned about Flow 3D Cast and not Flow 3D. I would be really grateful if you could share a screenshot of your recommended solution in Flow 3D Cast.
flow 3d cast, input conditions, pressure conditions |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
settlingFoam unstable? | bendel_boy | OpenFOAM Running, Solving & CFD | 38 | July 8, 2016 06:07 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
