Home > Forums > Software User Forums > FLOW-3D
PostProcessing of particle source
Old   May 28, 2017, 10:51
Default PostProcessing of particle source
boesendorfer is on a distinguished road
I've seen some papers which show the mass momentum source model in a nice way in flow-3d postProcessing. A large number of particles are generated in the void region and move all the time dynamically.
How can I get such an effort in the visualization?
Is it necessary to use flowSight? or flow-3d postProcessing is robust enough?
boesendorfer is offline   Reply With Quote
Old   June 1, 2017, 08:16
I think I should ask for a more recent version
Old   October 24, 2017, 09:15
Panomdei
Paraguay is on a distinguished road
you can do that by a plugin in 3dsmax software, called particle simulator I'm guessing, a very powerful simulation tool for particles.
Engineering software tutorial
Paraguay is offline   Reply With Quote
Old   October 26, 2017, 17:22
thunde47
thunde47 is on a distinguished road
You can visualize particles in FLOW-3D and FLow Sight. Obviously Flow Sight results will look much nicer.
thunde47 is offline   Reply With Quote
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 10:46
